View BGPv6 Imported Routes
Display information about BGPv6 imported routes.
Variable |
Value |
longer-prefixes |
Shows long prefixes. The longer-prefixes indicate the mask length from a specified prefix to 32 (for example, show from prefix a.b.c.d/len to a.b.c./32). |
<prefix/len> |
Shows paths with this prefix. The prefix is the IP address and exact mask length (must be an integer value from 0–32). |
vrf WORD<1–16> |
Specifies a VRF instance by name (the string length ranges from 1–16 characters). |
vrfids WORD<0–255> |
Specifies a range of VRFs by ID number (the ID ranges from 0–255). |
